Blocks Used In MODBUS Comminication
vic_yubal
Aug 2011
Saudi Arabia
Masters,
Does anyone here have an Idea on what BLOCKS to be used to read/write registers using MODBUS RS-485 protocol?
I am using Unity PRO XL software and my PLC is a Quantum family which model no. 140CPU67160,HSBY. Thanks in advance.
Modbus
Hello,
may be you could take a look for the MBP_MSTR library.
You can use it from different ports such as Ethernet and RS485.
F.
I have read this block but I think it is for Modbus Plus port..I am connecting on Modbus Port only..can this block works? Is there other way to used this because I am trying this block it works only for MBP or Ethernet..Can anybody have experience on this? Thanks in Advance..
Modbus port
The 140 CPU 671 60 has a modbus port (and a modbus plus one).
When you double clic on the cpu, there is a Port Modbus tab.
This port is the RJ45 upper one in front of CPU.
I look how to adress the modbus port and tell you.
F.
Modbus
Hello,
you have to use XXMIT for use Modbus port on CPU.
Please take a look at documentation, you have to fill a lot of parameters.
Good luck !
I'm trying to locate the usage of hidden data blocks used only by the processor. The block folder doen not contain this data block. Is there...
1,653
Reality Check Question: For a Function Block Diagram, can I safely assume that a function will not output ENO until it has completed execution...
8,884
I'm trying to include MOVs and fuses for solenoid PLC outputs in a panel with limited space. Does anyone know of terminal blocks that have built...
246
Good morning crew! Ok my logic works but I am missing something. When the start button is pushed it should like the red light for 4sec then shut...
451
I'm a bit confused about how symbols and UDTs work... As far as I know, in offline mode FB gets symbols from the UDT declared in the "state"...
434
