Books of the Bible
Zecreamdix
Apr 2024
South Carolina
Hello,
I am a Sunday School Teacher in my spare time. At a young age we begin working with our kids in attempt to teach the Books of the Bible and in order. I have a friend that has a CNC Router in which I was thinking of having him take a 4" x 3" sheet of oak and have him mill in the Books and give me a hole for an input push button to be installed. A corresponding second for a green light for a correct choice. This will make me need 70 Inputs and 70 Outputs. Is there a way to make this work without spending $1000.00 on expansion slots or using an HMI?
Some random thoughts on this:
-This might be a good application for a Raspberry Pi or Arduino, in a few possible ways. I haven’t seen that much GPIO on one setup, but I expect it’s available. As an input device, one could be setup to output a string to a PC or PLC that corresponds to the input actuated.
-Two pole switches are common. To reduce inputs, you could multiplex switches to each turn on a unique pair on inputs. Sixteen inputs would provide 64 double inputs plus 16 singles to do 80 switches.
-Multiplexing outputs isn't as friendly. It would take a bunch of relays to multiplex an array of outputs provided you only will ever need one light at a time.
-The common PLC way to do this would be all touch screen. That’s fine for industry, but a wooden board sounds really cool and special. I hope you do it.
-Once upon a time I might consider doing something like this with 7400 series logic. Nowadays, a FPGA would be the way to go. Maybe not so practical for a one-off system, but it’s another random thought
-So, with a Click… one 16 point in, five 16 point out, is about $380-ish, plus the controller. And a bunch of switches and lights… And a power supply… And wire it…
How are you going to drill 70 holes and have 70 readable text strings in a 4" x 3" sheet of oak? I presume you mean 4' x 3'!
You could reduce the number of inputs needed by assigning switches to rows and columns and using the combination of two switches to define a single book. A matrix of 8 rows and 9 columns requires only 17 inputs and gives you 72 unique combinations of one row and one column.
To elaborate on what Steve is suggesting, you can also do the output lamps with a matrix and a bunch of blocking diodes. Pinball machines used this method for most of the 80s to 2000s. Search pinball lamp matrix. They also had a switch matrix similar to what Steve described for inputs.
Hello all, Has anyone bought the 4 books (Beginners, intermediate, lab, and electronics) from this website? Do you recommend them? As things have...
1,437
Hey all, Can you guys recommend good books which can automation engineer should read. I scanned a few books on plc programming and most of them...
2,451
Hello Guys, I just started learning about programming PLCs, I know very little to nothing about communication between PLCs, and have trouble...
969
Hello, hope you guys are well today. Our company recently purchased some machines with Siemens PLC. I have worked for few years with Allen Bradley...
2,799
Hi to all, I would like to know what are some good books to learn Rslogix 5000? I am familiar with Rslogix 500. I was looking on Amazon and other...
1,713
