Bootp-dhcp
Prayder
Jun 2014
Arkansas
254
I am trying to understand why every time I open the BOOTP-DHCP utility I constantly get a message saying:
Cannot find a valid IP Address
Application cannot continue
Fix network settings or connection and retry the applicaiton.
Prayder,
I am assuming that you mean Allen Bradley Bootp.
Before using the bootp program, you must setup the initial program config file using the bootp-dhcp server program.
Sorry, this is as far as I can take you. it has been several years since I used it.
regards,
james
Are you trying to run the program before you have a network connection established? (i.e. before you plug in the Ethernet cord?) If so then there's no IP address on the port and that might be why it's complaining.
I have used this software lots,
First of all remove all other devices and hardwire straight into the device you want to assign the ip address to,
then set your lan conneciton to dynamic.
Open the software and under options/tools or config not sure what its called, enter in the subnet mask 255.255.255.0 and nothing else
then select browse and wait till you see your mac address...
then select the devices mac address and make sure in shows up in the bottom window
Next there are differences with certain devices....some you can just assign an i.p straight away, others you need to go back to your Lan ip settings then put your network card in the desired range i.e static ip addressing
if you want your device to be 192.168.1.2
subnet 255.255.255.0
your laptop will have to be 192.168.1.xx ''anything other than 2''
255.255.255.0
that should do the trick,
then go back to the boot/p software that is still running and disable the bootp etc
few other notes, the mac address can take a long time to pop up so be patient 5mins and it should be up by then
your device needs to be broadcasting its mac address so make sure thats happenig
also some laptops have firewalls that stop this software from working so dont be afraid to use another pc/laptop
I realize I'm resurrecting an old thread, but this was the only hit here for the OPs problem and I encountered it today too. I found that I had to disable all the Ethernet ports that were not in use and showed as Network Cable Unplugged in order to get the utility to start. Hopefully this helps someone.
You must have some type of active network connection talking to the laptop. It can be wired Ethernet or WiFi. Altho not both at the same time.
636036 - BootP will not open, "Network setup error. Cannot find valid IP address"
Access Level: TechConnect
  • Try Plug the workstation computer directly into the device
  • Disable all other Ethernet adapters, including wireless Ethernet adapters
680084 - BOOTP-DHCP Server shows Network Setup Error
  • Check Local Area Connection is Enabled
  • Check Local Area Connection is not set to Obtain IP Address Automatically
  • Make sure you are using a crossover cable (if no Auto MDI-X support)
Regards,
George
Your network cable is not connected.
Hello all, I have a 1732ES-IB16 Series A block that I have set the IP address on. I am unable to disable bootp using any method. I have tried...
354
I am not sure what i am doing wrong laptop ip 192.168.1.233 with subnet mask 255.255.255.0 micro820 ip unknown 1) i connected a micro820 and my...
3,935
I had a 1794 AENT ethernet adapter card go bad. Tried to replace and cannot seem to get the replacement to work. I've tried everything I could...
1,879
Hi; To assign an IP to a device, I have installed BOOTP/DHCP server (by Rockwell). By following the instructions, I send IP to a connected...
5,340
I have a Compactlogix with a 1768-L34 Processor and two 768-ENBT network cards. I assign a IP address b adding a relationship and we are good...
3,486
