Borescope / Fiberscope / Inspection Camera
VJTX
Oct 2007
TEXAS
126
Has anyone any experience with the low priced fiberscopes? One use I would have right away would be to examine the dip switches for the settings in a place I can't quite get close enough to read. If you can recommend one up to about $300, let me know.
Good morning guys, I'm searching to find a product that can inspect the width and depth of a keyway on the end of shaft. Width is 1/4" ±.001...
289
Hi All, I'm doing mainly PLC programming but dabbling in industrial networking. I am investigating an intermittent communication fault between a...
1,714
Hello, I have been shopping around for a while, seems like alot of them will only inspect a small area. What I want to do is inspect a loading...
1,896
Hi Group My control box uses 110VAC incoming from customer supply. It has a PLC and a DC power supply both running on 110. The PLC draws 0.8...
1,706
Could someone suggest any instrumentation to internally view non conductive material? Example : Validate a centered wick in a candle internally...
1,485
