jcraft
We have a small servo motor for a spiral tube cutting machine. the motor drives a 5 to 1 gearbox which is belt connected to a cutting blade assembly and we are controlling the velocity of the motor only . This is a new install and every thing is setup and running. The question is we run the blade above 75 rpm ( 375rpm motor speed) the motor starts to emit an annoying humming sound and increases intensity as you speed it up, This is with only the gear box and cutter load. below this speed it is quite. We ran a test today and we were spiral cutting a 2" tube at 45 rpm cutter speed, Immediately the motor produced and even louder annoying humming noise when it is actually cutting the tube. I went online with the controller and actually reduced the Velocity Pgain from 5 down to about .680 and the noise was elimiated completely and the commanded and actual velocities stayed pretty much identical. Motor current waas at 50% and so was the tourque. MY question is, now that we eliminated the noise while under load when we remove the tube load you stll get the motor hum above the 75 rpm cutter speed. Not sure of what parameter settings would eliminate this. Any thoughts. Thanks
