Bosch Rexroth Visual Motion 10 Material Encoder
Manglemender
Jul 2007
Lancashire
1,295
Greetings Forum Members,
I'm adding a material lenght encoder to a 20 axis Visual Motion 10 application.
I should point out first that the axis driving the material (sheet steel) slips and so cannot be used to measure the material. A second encoder is being added to one Axis to be used as the source for material lenght.
What is the best way to access this encoder and turn it into Material Length?
My first thought is to use the ELS function but I'm wondering if anyone has any advice to offer or an example to look at.
Thanks in advance,
Nick
Pending on the type of drive you can use measuring wheel mode in the drive. It allows the drive to close the position loop around the wheel encoder, while filtering in the motor encoder.
Good Day I trust you are well, I am struggling to find someone that is familiar with the software "bosch Rexroth Indralogic Engeneering" I am...
1,529
Hello . I have some kind of problem with loading program into CLM 1.4. I have working controler which has first symptoms of coming failure...
1,270
Hi guys, My name is Kevin, and I'm doing internship right now. I need to make an universal denester, filler and lidder. Right now I'm designing...
4,344
Dear Sirs, in my current application, I am using a Bosch Rexroth L20 PLC communicating with Hightec PWS-6A00T-N HMI, but in the configuration of...
4,135
Hi All Bosch-Rexroth phases out DPQ and DPC cards. Russian office of the company advised to consider HACD-3 or HCN100 cards to control 2 axes...
2,044
