Branch nesting question
Yes, there is a difference. Using a ML1100 I needed to do three concatenate (ACN) instructions in order. I tried using parallel branching but it would not compile. Nested the three and it compiled and worked in the proper order.
Shawn
Thats strange.
I just tried
SOR BST ACN ST10:0 ST10:1 ST10:2 NXB ACN ST10:2 ST10:3 ST10:4 NXB ACN ST10:4 ST10:5 ST10:6 BND EOR
for a ML1100 and it worked just fine. Whats the exact rung you tried?
I think I figured out how I came to that conclusion. I started with this:
XIC B3:0/0 BST ACN ST9:1 ST9:2 ST9:3 NXB ACN ST9:3 ST9:4 ST9:5 NXB ACN ST9:5 ST9:6 ST9:7 BND OTL B3:1/0
It would not compile. When I clicked on the error message in the popup tab at the bottom it highlighted the branches. This led me to believe that the branching technique was wrong so I changed to this:
XIC B3:0/0 BST ACN ST9:1 ST9:2 ST9:3 NXB BST ACN ST9:3 ST9:4 ST9:5 NXB ACN ST9:5 ST9:6 ST9:7 BND BND OTL B3:1/0
Still errors when compiling. My final rung looked like this:
XIC B3:0/0 BST ACN ST9:1 ST9:2 ST9:3 NXB BST ACN ST9:3 ST9:4 ST9:5 NXB BST ACN ST9:5 ST9:6 ST9:7 NXB OTL B3:1/0 BND BND BND
I never changed from nested to parallel and from all the time I spent looking at the program I had convinced myself (incorrectly) that they needed to be nested.
How do you expand a branch in connected components workbench. Example i want to add an interlock around more than one contact. Most software you...
1,285
I'm trying to use proworx32 for the first time and can't seem to insert a vertical short between blocks. When using the [| Short] button from the...
1,052
Good afternoon, Does anyone know if a circuit containing 3 Kinetix 5500 drives (& their motors) is considered a Motor Branch Circuit according to...
2,721
Is there any reason I couldn't use a 140M circuit breaker for branch circuit protection of something like a control transformer or power supply...
3,553
Hi guys! I have been spending quite a bit of time yesterday and today trying to get a definitive answer to this question regarding protection an...
3,802
