Expanding a branch in Connected Components Workbench
jsock
May 2023
Lakeland FL
How do you expand a branch in connected components workbench.
Example i want to add an interlock around more than one contact.
Most software you just drag to point, but i have had no luck.
Thanks,
First drop the branch on the rung, then drag your contact to the branch... then you can add more
Are you wanting to join them? Maybe the issue is they are the same? do you have two NC WS201B_...INSE_ON?
So this is what im talking about. I want to expand around several contacts.
If you want to know how to add a branch, follow GIT's pic I cropped.
Click the rung right of the instruction(s) you want to branch around (orange ellipse) then click the branch icon (orange circle)
That will place the branch in between the 2 instructions, then click & drag the left side of the branch to encompass all the instructions you want to branch around.
I figured it out.
You have to drag the contacts in upper rung inside of of branch.
[/ATTACH]
Is good you found a workaround, CCW is not exactly intuitive.
I am not sure if it's in CCW or tia, but you can also select an instruction by clicking it, or multiple instructions via shift-left-click, then right-click the selected instruction(s), and in the pop-up that appears the will be an option to insert something, and a pop-up to the right of that there will be an option to "surround with branch," IIRC.
Again I might be thinking of Siemens TIA, but I know I have seen this somewhere.
I have a project/program that I am recording a time stamp and its using DS1-DS6 and shifts this down every time there is another 'event' because...
2,246
Hi , I am not able to expand any global variable in offline mode, also not able to add comments to the elements of the variable since it does not...
3,235
Hi Guys When i expand my networks in TIA v14 it doesn't expand the SCL networks. Unless there already expanded! Is there a trick I'm missing? TIA
2,030
Hello all i started my current job april this year where i became the companys Main electrical guy and plc programmer, before that i was in...
30
16,095
Good morning 1400 b Micrologix PLC, Question; the unit come standard with 128Kb of memory for data logging, is there an expansion module...
2,536
