Business Card Question
Marc
Jun 2004
Nashua, NH
430
What do you guys call yourselves on your business cards?
I just got a request for an updated business card and have been pondering the "title" part. I do panel layout/design electrical schematics, product specification load calculations PLC programming, HMI programming, Scada programming, networking, SQl integration etc. etc. Basically soup to nuts for a custom fabrication UL listed OEM on the electrical/programming side.
Marc
I've been a " controls engineer" before. Now I'm an "Automation Specialist."
You need to be careful, because you are sometimes required to have a P.E. license to call yourself an engineer. Or, you could skip the license exam and become a "Sanitation engineer."
kcarlen said:
What if you are not an Engineer by Degree?
Then it would be "self-proclaimed engineer" that way the door is left open for an escape for those small mistakes :ROFLMAO:
Mine says "SR. Field Service". I leave the engineer up to the imagination of those I give my card to. By training, I am an "Electronics Technician". That is what I tell the IRS on my tax return. These days you have to be careful of using "engineer" in your title. Some states require you have the PE and be registered. Some companies call every one an engineer.
Don't over sell yourself and you will be fine.
Your right, I checked NY state and you can't say "Professional Engineer". Hopefully that'll change for me this October (fingers crossed). These rules may vary from state to state. The main thing seems to be that you can't give the impression to your customers that you are a P.E. if you're not.
I use Controls Engineer, but I work in industry as an end user so it doesn't really matter.
The rules vary from state to state, but my understanding in general:
If you do engineering designing public facilities, you can't use "engineer" unless you are licensed
If you work for a manufacturer and not directly on public facilities you can call yourself "engineer" if you are degreed or if your employer gives you the title engineer, degreed or not
If you are consulting or freelancing you shouldn't call yourself engineer if you aren't licensed
Most states don't have the same restrictions on "designer" or "technician". These are good fall back titles. Note that some states do have licensing requirements for "plumbing designer" and such, but they don't resrtrict the use of the term designer nearly as much as they do engineer.
Since I run my own company I can use any title I want.
To avoid potential confusion between an engineering degree (which I have) and a PE license (which I don't have), I use the title "Automation Specialist" on my business cards. If I feel that something more impressive might be useful, I also carry some cards with the title "President".
At my company, only degreed engineers have the "Engineer" title, such as
Chemical Engineer, Electrical Engineer, Production Engineer, etc.... The P.E.'s use the same title with the P.E. added to the end.
Anyone without an engineering degree, but preforming the same work is called a "specialist".
My current title is: "Process Controls Specialist"
I put in a free request for a controls magazine once, under "title" I put 'Head Master Controls Beach' (you can guess the correct spelling). Thought it would be funny having that show up in my office once a month.
Needless to say they never sent it, I had to re-apply with my title 'Control Systems Engineering Supervisor' I don't think my company could have come up with a longer title, it doesn't even fit on the address label.
When I started with the company I am currently with they put 'Controls Engineer' on my cards. When I sent my resume here I called myself a 'Control System Specialist' since I am not degreed.
If I had a choice I would stay away from the 'engineer' title unless you are degreed, regardless of your capability. It may end up saving you some explaining if you run into someone who is too 'title oriented'.
Keith
I'm not sure what a degree has to do with any of this since the Merriam-Webster definition of engineer in this case is:
b : "a person who is trained in or follows as a profession a branch of engineering c : a person who carries through an enterprise by skillful or artful contrivance"
All the other definitions had to do with knowledge literally of "engines".
A college degree has nothing to do with experience, but arguably you may have some "'splaining" to do at an interview. If you have the experience in design, debug, and all that goes with it, and can back it up with producing quality work, what's wrong with that?
Bill Gates is a pretty good businessman, without having a college degree in Business or anything for that matter.
I am new here and I just lost my job or 8 years today. I am seriously thinking of going out on my own but have so many questions. I have...
4,165
Dear Guys, I was thinking is there any possibility of making our automation service business to be passive. such that even if we are not working...
3,926
I know a lot of you are small businesses and you may need this... https://covid19relief.sba.gov/#/ Best of luck to you all
1,289
I just got asked a question on a local business website, and couldn't think of one. So, does anyone have any PLC/HMI jokes?
58
15,271
I'm having trouble finding insurance for my Single Member LLC. I'll be a self employed field service operation. PLCs, VFDs, etc., Troubleshooting...
2,243
