Button to open specific File on HMI
Micash143
Aug 2015
Greensboro
Using Factory Talk SE (network Distributed) client for HMI. Looking to see if I can create a set of buttons on a screen that will open up separate files on the server where they live. I have created some pdf files with training/technical information specific to the page that is displayed on the HMI. Instead of having my operators have to track this down in a book in the control room, I would like for them to be able to open it up and see it on the portable HMIs they carry around.
Use a button and some VBA script. Map the network location of the PDF's to a drive (the same drive) on each client you want to be able to open the documents.
Hi, I am using Cimplicity first time.I want to open a screen from a button.How I can do it?
2,346
Hi, im am wondering if anyone has used the open window button component with the Advanced HMI VB 2008 application. I have little programming...
5,289
Hello, I created a Wide, long file name Dbase Data Log Model to get information for some tags. It stores data in the path (C:\program...
6,012
in WINCC: is it possible to make a button to open a particular xls-file?
6,951
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
135
