Cable for connecting Panelview 2711-K5A5 (RS-232 DH-485) through AIC+ Link Coupler
plvlce
May 2017
Michigan
1,074
For connecting to a Micrologix through a 1761-NET-AIC, the manual specifies that you should use "RS 232 Communication Cables Cable, Cat. No. 2711-NC13 Cable, Cat. No. 2711-NC14 Cable, Cat. No. 2706-NC13" -- basically just a straight-through serial cable.
But it also adds 'Note: On PanelView 550 terminals, pin 8 on the RS-232 connector is pulled high. Do not use the 2711-NC13 cable.'
So what cable should be used on a Panelview 550? A straight-through cable without pin 8 connected? If so any other wires that should not be connected?
All other ports on the AIC+ are in use.
Hi there guys, At work we have some Siemens S7-1200 PLCs and have just got the Step 7 Basic software. Typically it has got to this point where we...
1,559
Do this happened to any of you ? I just succeeded connecting a ml1400 true a new XPmode VM by the means of ethernet. I used a direct cable from...
3,687
Hi all :) we have one following PLC. Platform :controlnet Processor :PLC5/40C Series :E-2000files/extended we bought one USB to...
2,173
Hi guys, I have a Siemens CP341-RS422/485 module and I am trying to establish MODBUS communication to a series of Multilin269 / 469 protection...
6,257
Hello everyone, first of all thankyou for all the help you've given me through other peoples' Q&A's. My situation is; -I am halfway through...
4,569
