Cad drawing ET200Pro series IO BLOCK
Hello Scmcmanus;
This the best i could find, dimension drawings from the ET200 Pro Faisafe manual:
A link to the manual:
http://support.automation.siemens.com/WW/llisapi.dll?query=ET+200+pro&func=cslib.cssearch&content=skm%2Fmain.asp&lang=en&siteid=cseus&objaction=cssearch&searchinprim=0&nodeid0=4000024
Hope this helps,
Daniel Chartier
Hi
If you are looking to create schematic drawings from this module then maybe you can use a new function in S7 V5.4 .In the Simatic manager you can export ( or import ) your hardware config .It store it as an XML file .
In menu Option\Cax Data\Export
Hope it helps
Eric
Siemens configuration tool
If it is a drawing of the module / node you can also use the ET200 configuration tool. In the tool is it possible to make a copy of the graphic view of the node (picture is send to the clipboard ready to paste).
The configuration can also be send to Step7 hardware configuration.
You can download the tool here:
http://www.automation.siemens.com/simatic/dp/html_76/produkte/benefits01.htm
Guys and Gals I have AutoCad Electrical 2004. I'm definitely no expert and just dabble with AutoCad. Can someone see if they can open this...
2,135
Hi, I am learning electrical drawing software now. I am trying to understand about this stuff but I cannot get the main point. How is the proces...
3,607
I need a 2D-CAD drawing for CompactLogix 1768-L45 and Kinetix6000. I'm just starting to get into PLC drawing as part of my job. I do not find...
2,191
Anyone knows where to find drawings of the MP270 ?
1,560
Can anyone help me, I am looking for a Micrologix 1200 cad drawing.
8,093
