Electrical drawing CAD general idea
SsshhH
Oct 2007
NL
I am learning electrical drawing software now.
I am trying to understand about this stuff but I cannot get the main point. How is the proces to use it in a industrial project?
Suppose I have a project to build a controler for "transport belt" with some PLC, motor, profibus, etc...
What should I do for the first time?
maybe it sounds silly question, but for me it helps me getting the general idea of the electrical drawing CAD..
Thank you..
The first thing you should do is find out the relevant electrical standards for the area where the machine is going, i.e. Europe, USA etc.
Jon.
You will need the IEC electrical block libary.
Using ACAD is the same as using a pencil
First plan your drawing.
1 page. this will show mains input isolation switch. power supplies.
2.page E'stops control...
3.
Actually have you got any existing drawings on ACAD?
Cant you look at that format and use it as a template?
So everything (complete system) are designed by the designer in general..right?
and then what happened with the specific hardware like PLC, Profibus,contactor,Fuse, etc...?
Does the designer also have to choose them?
Yes...I have ePLAN P8 student version.
3.
Yes. altho some large company's separate out parts to specialists.
Most PLC programmers will know how what hardware to use, do the ACAD drawing, and select the correct network interface, to talk to othr machines,
You need to have knowledge of the whole design. If you dont know the hardware you cannot write the program, if you have to know the hardware you are going to have to draw it for someone to built it so most here will know ACAD and PLCs and general electrical engineering.
That helps me to understand.thank you.
I am a student of electrical & electronic engineering right now.
I had PLC programming, Industrial Networking lesson, SCADA programming, but not the Industrial electrical drawing.
That is why I want to learn it.
Hi everyone, I am looking for someone to do an autocad drawing of an electrical circuit I am working on, I dont have cad, but I would like someone...
128
43,459
Hi, i am looking for an electrical drawing software package. I just need to be able to draw basic wiring diagrams. I would go for autocad...
27
13,272
Hello all, I work at a small company and there for wear many hats such as many of you I am sure. on top of being a Programmer I create Electrical...
2,868
I'm looking to purchase some sort of electrical software in order to produce electrical drawings, pretty simple so far right? My question is there...
19
13,273
Does anybody knows any free or cheap program for drawing electrical circuits?
22
8,833
