Calculating Allen Bradley I/O Module Power Consumption
red439
Dec 2017
Bangkok
Hi All,
I'm having some trouble on determining the total power consumption of the following I/O modules: 1769-OB32,1769-OF8V, 1769- OW16, 1769-IQ16. Can I use the heat dissipation values to compute for the load of each module or is it better to use the on state current and multiply it per channel? What is the right way to calculate the power consumption of I/O Modules?
for the OB32
Heat Dissipation,max is 4.5W
On state current min is 1mA
Current per point,max is 0.5A @60degC and 1.0A @ 30degC
Current per Module,max is 4.0A @ 60degC and 8.0A @30degC
for OF8V
heat Dissipation,max is 2.16W
Load output current,max is 10mA
for OW16
Current draw at 5.1V is205mA
Current draw at 24V is 180mA
heat dissipation,max is 4.75W
Current, per point,max is 2.5A
Current per module ,max is 20A
for IQ16
heat dissipation is 3.55W
On state current min is 2mA
Current draw at 5.1V is 115mA
Thank you in advance.
This application has a motor with encoder feedback that drives a linear actuator that moves in/out, and is at roughly 45 degs from horiz. As the...
19
1,369
I need to keep a running pass/fail yield of the previous 5,000 parts produced. I have used this formula before to calculate average: AvgValue =...
2,160
Does anyone know how to calculate the savings from now needing to run an air compressor all day? Basically I have a design that replaced 6 * 1"...
26
4,837
I would like to refer to this document of which I used some data ...
1,482
Seems like this should be a simple thing but I’m struggling with it. The basis is that I am trying to detect if a linear assembly is stopped or...
3,110
