My application includes positive displacement gear type flow meter (500 pulses per liter). PLC is ML1400
I need to totalize the fluid being dispensed. I’m thinking I should be able to simply take my HSC.X.ACC and divide this by the flow meters “K” factor to get favorable results.
A little background on the fill volumes to be dispensed, the max volume dispensed will be around 350 liters. With the pump I’m using the fill time should be around 6 minutes. I’m not too concerned about fill accuracy, (+/- 3L) would acceptable. Am I on the right track?
