Calculations in gx iec developer
AndersW
Jan 2010
Sweden
24
Im writing a minor system with a puls sensor and where the user of this system can put in values in MM now i need to recount this to pulses and i cant get it to work
basially I need to have value in mm(D0)-constant in mm(D1) and then the new value (D2) * with pulses per mm(D3)
I started using the sub function but i end up getting really wierd values when i check this
is there an easy way to do this? also preferably without having to add a lot of extra registers for the calc of the last part
sub function with the answer to add function would be really nice
would love if anyone could help me with this, thanks in advance
I suggest you let us know which mitsi plc your using and post a shot of your maths code or better still zip the prog or part of it up and post it here and you will get a better faster response especially from the Mitsi fans (saying no names :) )
Had to upload it but this works
This is what id like to do but i cant even get a value that makes sense coming out of the sub function if I put a register as output when I try it
What registers have you got to the input of the sub and what have they in them ?
(Im not a mitsi fan (n) but as the mitsi boys seems to be down the pub with their ties ill chip in !)
so basically you want
(D0 - D1) * D3 = Result
If so why are you using 'ADD', try MUL
DINT variables, and i guess they should have started at 0 but they didnt for some reason
Would like to see what feeds the D registers, he may be overlapping registers using Dint's, try seperating D0 then D2 etc
Yes, thats what i thought, which is why i asked what registers he's using exactly. Been 2 years since i touched GX now though *TOTAL BLISS* so was having trouble remembering :)
In a safety circuit it's clear how to use sistema or similar to calculate the PL given hardware components. But how are various degrees of pure SW...
97
I know this isn't PLC related, thanks for bearing with me. Does anyone have an excel sheet to calculate full load amps for branch circuits? Im...
726
Has anyone had any experience with calculations for SRML wire. I have searched through all the articles I can, googled it and even talked to...
1,706
Hello experts, I'm making my first steps in hydraulics and recently I have come across to a very old thread in which the following task was...
3,107
Hi All, I have a task to decipher a calculation done by one of our S7 PLC's onsite. The problem being that its in statement list, and this...
1,861
