Calling a program in Crimson 3
Ramric
Jan 2012
Australia
I have mapped data tags Vlt_1 and Amp_1 from a device_1 (with ip address) to a red lion programmable controller which is connected to it over Ethernet radio by making the data source of the data tags as the device_1 with opc address as Vlt_1 and device_1 with opc address as Amp_1 respectively.
I have also mapped the output modules (CSOUT4) terminals (first 2) with data tags Vlt_out and Amp_out.
I have tried to assign the output module terminal data tags to the device data tags above in the data actions on write general at the tags but get circular errors so have resorted to assigning the data tags in a program with protype program1(). But I am unable to call this program. I changed the properties to same as caller, background, read when referenced, run anyway etc. I have placed and incremental counter to see if the program is being called but apparently not. Can anyone help?
This is a strange one, I have a simple alarm filter function block done in Structured Text (ST). I am calling it from a program. When this program...
15,467
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
147
I am looking to get an AB series 1774 (PLC1) from the 1970's up and running. I have all the parts, and it powers up just fine without errors if I...
2,327
Hello all, I’ve recently begun using Automation Studio on my own time to boost my knowledge of controllers beyond AB/Siemens. To ease myself into...
901
Hello I'm new to PLC programming and I'm programing in ST. Programming envirement is GX works 3. I can't figure out how to jump to subprogram or...
1,465
