Calling Devicenet Gurus !
504bloke
Jan 2005
Down South
2,721
Hi
i am looking at a project that may use a
KS Vario Bus System for temperature control
See http://www.pma-online.de/en/products/vario-menue.html
I am looking at conneting an slc to it over devicenet
Now my question is looking at the eds files found here
http://www.pma-online.de/files/eds-gsd/edsksvario.exe
When i use the ks-vario-dn_30ch+config eds file i get a parameters tab for the vario when i double click on it, these go from ID 1 down to ID 5654 ???? I see i can alter the Thermocouple type etc etc but what exactly is this for ?
And the IO Data is 254 Bytes in and 254 Bytes Out
So will an M file transfer get all info i need or do i need to explicit message ?
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
153
I am looking to get an AB series 1774 (PLC1) from the 1970's up and running. I have all the parts, and it powers up just fine without errors if I...
2,332
Hello all, I’ve recently begun using Automation Studio on my own time to boost my knowledge of controllers beyond AB/Siemens. To ease myself into...
906
Hello I'm new to PLC programming and I'm programing in ST. Programming envirement is GX works 3. I can't figure out how to jump to subprogram or...
1,467
I have some code i need to block until a super genie for data entry has completed (by operator input)as per below. FUNCTION New_Setpoint()...
2,280
