Calling Mitsubishi Gx Developers....
garryt1
Jun 2002
n.ireland
128
I have a mitisubishi fx2n plc i am trying to change timer values but the change tc settings button under edit is blanked out,maybe when you go online with the plc itself this changes,can anyone help me on this as i have never used the software.
Thanks in advance.
I have not used the TC that you talk off, mine isnt greyed out either although it appears to do not alot?
To change a timer value open the program and double click on the timer ie T100 K200, an edit box opens up, change the K value for the time delay.
Thanks in advance.
You are in read mode cange to write mode. Regards Badger.
Hello friends; I am new with Mitsubishi system. I need some example to handle the 4-20mA by using FX-2n-4AD which is attached with FX-1N-14M...
3,567
Hi All. I am trying to do something here that I am beginning to think Mitsubishi won't let me. It seems it ought to be possible but I can't seem...
10,016
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
168
I am looking to get an AB series 1774 (PLC1) from the 1970's up and running. I have all the parts, and it powers up just fine without errors if I...
2,337
Hello all, I’ve recently begun using Automation Studio on my own time to boost my knowledge of controllers beyond AB/Siemens. To ease myself into...
914
