Can a PLC receive a signal from a GSM modem?
smsman
Sep 2003
I am new to this forum and i have a very skeletal knowledge in PLC's(comes form my 4 month exp. working for an autmation agency that supported keyence).
Is it possible for a PLC to receive a signal from a gsm modem and runa program or take an output from a program and send the o/p through a gsm modem? I dont know the basics of requirement for such a system, can some of you throw some light on this.
regards
smsman
I have heard Beckhoff PLC have a module to interact with GSM modems - you may try to explore on the net for info.
You can connect a modem to a Basic Module/Comms card in a PLC or use the Default Serial Port. I know you can configure in AB, GE and most PLC's.
The PLC program and the Basic Program in these Modules will do what you intend an Input or Output should do.
Currently,we are facing the communication go through with 422 tx+ and tx-. Mitsubishi fx5u series is used and using command rs2. But the package...
108
Hi all, Silly question.. We are working on a project where customer receives email in case of alarm. (Siemens S71200 + TP700 Comfort). Now...
4,039
Dear All I have some trouble. I'm trying to send message from module 3G GSM to port 502 of PLC M251 through internet. - Port 502 of PLC M251...
2,314
Hello, My task is to upgrade a control system based on SattCon OP45 PLC to a Simatic control system. I have some questions : 1- What is the...
1,464
Hello, I dont have any experience with PLCs, but i need to write a program that sends data to a PLC (basically, sequences of INTs), a...
4,959
