Dave, that is great! I think it will be a good start for Bebenona. Probably you did not see the small addition (change) that I made to my rung 003 (your Rung 16). On the branch next to the M1 contact, there will need to be a T1 normally closed contact to stop the timer after some time period (actual time needed unknown at this point). M1 keeps the timer running until the Stamper and Wheel are reset, but then needs to drop out.
Also, on your Rung 4, the comparsion block should look at T1, not T0. We want the Parts Wheel to reset when T1 reaches some time value (unknown but I guessed as 3 seconds). That is one reason that I used comparison instructions instead of just the timer bit, so that one timer could be used to reset both the stamper and the wheel. The wheel will need to stay on until some time (I guessed as 1 second) after the stamper is deenergized, to give the stamper time to retract out of the way.
