Can anyone recommend a good GSM texting 'box'
Goody
Apr 2002
Huddersfield W Yorks UK
1,081
I have a customer that has asked of a method of being texted should a fault occur during none working hours.
They do galvanized dipping on a huge scale and the pot must stay molten during the night and weekends.
I built the control panel a while back and it has a Mitsubishi PLC and HMI with plenty of spare I/O
I have had a look around of course but I would prefer some recommendations from people who have installed them.
There is no networking involved - just a 'box' GSM capable with several inputs to text different fault problems to different people.
I've used comlink in the past, easy to set up. But limited in number of alarms.
http://www.comlink.se/
I know Mitsubishi had some standard solutions to send alarms from the PLC through a modem, allowing you to send values and status signals. Maybe your Mitsubishi rep can help you. I guess that would be Beijer in the UK.
There is no telephone line available.
But the one I saw was basically a cell phones guts in a box (mobile phones to us Brits) - it even came with a free sim card that doesn't cost anything to make calls or texts.
Outputs from the plc triggered pre-written texts within the 'box' to designated phones.
No telephone wires just a box inside the panel with an ariel if the signal is weak.
I have used several of these -
http://www.remmon.com/en/products/remote_terminal_unit/sms_data/rcom.php
does exactly what you have described except no free sim.........
I have used TELTONIKA http://www.teltonika.lt/en/ TWCT22 in several projects and am quite happy. I still have few in stock for small projects. It has 4 digital inputs/ 2 analogue and 4 relay outputs. Many combinations to whom to send SMS if an error occurs and it also has some logic gates which you can use. Can sync its clock via Internet- GPRS
Hi everyone. I would like to know what are some brands you have had good experience with and what to stay away from. And do you have any...
3,053
I had a chat today with a contractor and he notified me that Rockwell will stop producing the Flex Ex IO modules from December 31st. The ones we...
1,660
I'd like to install one to notify operators of production rates and error conditions. We have an HMI, but it's not easy to see from where the...
2,246
Hi, We are looking at getting some full bottle label inspection equipment in the factory where I work. We currently use Mapex and they are quite...
7,858
Can anyone recommend a simple Barcode Scanner? I will be using port 2 of AD 260 CPU and I only need to scan a 7 digits Barcode number into...
7,727
