Can I make FactoryTalk View SE Graph from Left to Right?
ehhakeoiiijge
Nov 2012
awe
21
The default trend has the pens on the right and historical data is shifted to the left over time. Is there a way to have it do the opposite?
Thanks in advance!
Hmmm, not quite sure WHY you would want to do this, as it makes the X-axis (the time axis) backwards, and is clearly going against accepted practice and convention.
Anyway, a shorter answer is no, it can't be done with the RSTrendX control.
Of course there's nothing stopping you from writing your own ActiveX control (or getting someone to do it for you), but that is way, way above my capabilities.
Laterally thinking, you could put a mirror at 90 degrees to the HMI screen and look at a standard trend in the mirror....
Thanks Daba.
Here is the situation. Maybe you can suggest a better way to do this:
We have a cook cycle which is supposed to connect a number of setpoints we have assigned it at various time markers, eg. 50C at 5:00, 60C at 6:00, 80C at 10:00, and 100C at 15:00.
We want the chart to show the expected values at these markers and then follow the curve with the real data as it happens.
How would you do this Daba?
Overlay charts are one of the things that the Trend object in FactoryTalk View is not good at.
It's always a continuous trend with time increasing along the X-axis to the right.
There are other software packages with superior overlay and SQL plot capabilities, in particular Ignition.
I've had very good success with .NET products from Nevron Software, and they have an ActiveX chart product that might integrate with FTView SE's live data. You could give that a look.
Thanks Daba.
I would plot the setpoints as well as the temperature. Of course the setpoints would give straight lines, but the temperature can be viewed as it traverses from one setpoint to the next. On one trend, you would be able to have up to seven setpoints, plus the temperature pen.
Something like this ? perhaps....
Thank you very much Ken and Daba. For our project I think Daba's solution will work best. Thanks for taking the time to demonstrate it so clearly.
Thanks!
A customer of ours is running FactoryTalk View SE 6.10 and has been having a problem with the data graph. Customer states that the graph going...
4,223
Hello, I want to connect the Factorytalkview ME with rslogix500 to see the live response of HMI buttons in Rslogix500 ladder code . I am using PLC...
52
Hello, I have a panelview plus that reads from 4 different PLC's. 2 of these used to be Micrologix PLC's and someone else went and updated them to...
128
Hi. I need to create several alarm servers in an application, but first I need to know if there is any impact on communication, or if more...
89
Hello all, I'm having trouble opening an application. After clicking open I'm prompted to login and after putting in username & password it...
91
