Can some body help please!!
Oct 2007
abbottabad
REAL TIME CLOCK (RTC)
I am using LS industries GLOFA PLC model GM4 (www.lgis.com)
i am using GMWIN as a software for its programming and it RTC_SET function
I need to use real time clock signal in plc ladder programming
i have used a function RTC_SET and by giving the exact parameters when i compiled the error came
"F/FB is not registered in library"
how can i use this function
or
how can it be configured
plz o_O
Hello sohailmushwani;
I found the GSWIN error message list through Google:
<http://www.takacszoltan.eu/elektronikacd/LG_leirasok/SZOFTVER/GMWIN_szoftver_ismertetese/GMWINA001App1.PDF>
Here is what it says about your error message:
u F/FB is not registered in library
The function or the function block that is using now is not the basic library or the function/function block which is inserted in the project.
It happen when the inserted library is deleted on the project after editing LD. Insert the function which is using now or the library
which has function block.
Not knowing GSWIN, this is a guess, but I would look into re-instaling the function you want to use from their standard library list.
Hope this helps,
Daniel Chartier
I need software driver Q2HBM110M . fix modify parameters for DRIVER model:Q2HBM110M, I don't know. where is software? fix setting programmes for...
1,373
please hepl me upload plc omron CPM1A I have a question for everyone i hepl everyone help me i have a types plc omron CPM1A and CPM2A, i when...
3,030
Ok I am trying to understand The AB DF1 protocol in order to use it in a visual basic 6 Application with the objective of makes a simple 232...
33
14,378
I am in the process of replacing an Omron (made by Yaskawa) vfd that is on a machine. We are replacing it with a Yaskawa. The old vfd died and I...
1,583
I keep all my Siemens licenses on a USB drive due to using it on multiple computers. I have not had a problem for years until last week when I...
4,002
