Yes.
This refering to local temp variable #state_bits I understand.
In temp I have stright address to proper W in DB.
ook again
there is opened db #base
after it there is loaded word refered to temp where is address in db. ok, I get it. but in db I have DW. which word is loaded (dw 12 - w12 or w13 ??)
But with descripions if I look at this word that isn't it !! ?
You follow me ??
I don't understand a lsb and msb in combination in addressing.
For me for example if I have dw 12, so CPU loads which W in dw 12 ? w 12 or w 13 ?
next question:
after loading #state_bits there is loaded int 1 . into accu 1 ?
and w # state_bit goes to other accu ?? where
and in this place in accu 1 ? ( I suppose) is loaded int 1???
after is is proceeded AW (and word) so I filter only last (most lowest lsb) in #state_bit. right ???
then is operation L 1. where is located ??? after instriction AW.
what is checked ??? to derive JC?
<>I in known me no problems.
and jump conditional no problems.
Thank You
L D[AR2,P#0.0]
