Can someone please help me create a save button ?
jsalzm1
Jun 2015
Houston
23
Im trying to create a save button that will allow the data once inserted in the form, save to a notepad file. The file can be accessed later for records. But I need to be able to save the information into notepad using Visual Basic. Can anyone help? a picture should be attached of the form
the DISPLAY HOSE button will be used later. Please ignore
To create a text file in VB:
Code:
Dim textfile As New System.IO.StreamWriter("file path")
textfile.WriteLine("First Line")
textfile.WriteLine("Second Line")
textfile.close
The above will create a file, you just have to specify the path (including file name and extension). It's up to you on how you want it formatted. I'd recommend just creating a basic file with "Hello World" in it so that you know how it works, then start adding your information to it.
If you want to get to a location like the users Desktop you can use:
Code:
Dim filepath as string = system.environment.GetFolderPath(Environment.SpecialFolder.Desktop))
This will return something like "C:\Users\myusername\Desktop"
If a programmable controller controls the operation of a motor, what connects motor control to the PC? A) Line voltage B) I/O device C) Modem D)...
27
7,151
Rockwell Migration guide did not state any action for the correction of below error: Screen 4 - 82PK961C_D: Message display object will be...
1,852
Can someone please convert this file to PDF from RSS thanks,
2,216
im trying to do this secuence but it dont work :(
2,601
Our instructor never taught us how to use the internal address or how to interlock. Any help would be appreciated! Thanks in advance...
29
7,266
