Jrivers010
So i made this thread yesterday. http://www.plctalk.net/qanda/showthread.php?t=111208
and i decided to give it a shot and work little by little. turns out, I can do more than i thought.
So i am working on one of the projects given on a Udemy course, and this is the problem statement. http://imgur.com/a/vc7E8
I wrote my program and i got it to clear test criteria 1. As you can see, the goal of this is to auto start the belt. once it hits the proximity area, shut off motor, and drop either one of the nuts, and sensor level reads it if full and it stops it. then it starts motor again to carry it off.
I tried to use a jump command for the "restart motor" part of the code, but it turns out the motor just stays on even when I force on the Proximity switch on my emulator.
https://www.dropbox.com/s/q7zafq0kccgpvt6/Re-Do.RSS?dl=0
why is that? how come its not working as i intended? (which was for the jmp command to only work ONCE, when the Lvl sensor bit is turned on. Going back to trigger a motor restart)
