Can you explain Rockwell BootP Server
IN RSLINX configure the EherNet/IP Driver to detect the device it should scan and find it. After it finds it then right click on the device in the network tree and choose Module configuration then go to the Port Configuration tab. You can reset the address there instead of using BootP.
I'll give this a try. Thanks
RDrast is correct that it will not find connections unless the subnets are the same. But if you right click on the EtherIP Driver in the window tree and select Drive Diagnostics you will see all devices that are connected even with different sub's. As shown in the picture below. My Laptop is set to 192.168.0.123 and the driver found 192.168.0.46 ENBT/ A Ethernet card. But the Driver Diagnostics shows 192.168.135.1 ENBT/A Ethernet card also.
This is something I just discovered after RDrast made his post. So maybe we all learned something new. Good Luck with your project.
Chris
Good evening , I was looking thru some Rockwell Automation programs , and took notice in some programs , UDT’s , AOI’s , etc. the NOP...
3,179
This is a bit of a rant lol, my first 5 years as a systems integrator was using Siemens, then I came to the dark side of Allen Bradley / Rockwell...
67
23,794
and then when i open the windowmaker, intouch is shutdown... that's not work that's demo I have 30days demo
179
Hi All In my plc program in following picture there are functions FC50 in the begining and FC51 in end of organization block OB32. I can not...
970
Just for readers in the US, when I write 'gas' I mean it as a state of matter, not shorthand for gasoline :-) I don't understand the logic of a...
39
11,178
