Cannont view GE Proficy Project Folder
tlona
May 2007
New Jersey
33
The client has sent me a GE proficy project folder that was copied from the /build/local/ directory. I am trying read the file using Proficy Machine Edition but cannot change the path where the application reads the files. Both GE Proficy are version 6.0. Does anyone know how to read/open a project folded that was created by a different PC?
I assume you are talking about Proficy Machine Edition.
Your client needs to make a Backup of the Proficy Project. With Proficy open but not the project, right click on the project name in navigator and click Backup. This will create a .zip file they can send to you.
Once you have the .zip file, open Proficy ME and right click on My Computer in the navigator, click Restore and point to the .zip file you were sent.
This is the ONLY way you should move Proficy ME projects between computers.
i have 2 backups: *.PVC and *.pvd file types thanks in advance for any help
67
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
41
I'm at a loss here and hoping someone else has seen this: Background: We've got two identical machines on our floor (we'll call them machine A &...
62
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
40
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
222
