Cannot Browse Past Ethernet CARD ENBT
whussain6
Oct 2013
Newcastle
108
Hi Guys I can ping my Ethernet card and browse to the Ethernet card (ENBT) using RSLinx V2.59. But I cannot browse past the ENBT. Cannot view the rack or PLC. From the other computer which has RSLogix5000 I can go online with PLC. But his desktop has only RSLinx Calssic and FactoryTalk System plateform. Any ideas Please?
Moreover If I start RSLinx Classic as service it will not show in the bottom pan, neither can I open it from Start>All Programs>Rockwell software>RSLinx Classic. It shows running in RsLing Classic Launch Control tough.
You can use the launch control to start and stop RSLinx as a service.
If you stop it, then you can run it from the start/Rockwell software ... menu and it will run as an application (not as a service) and then you will find it in the tack bar and be able to modify drivers, etc.
Cannot browse past ENBT to the backplane
Yes, I know that I can start it as an application but still cannot browse past ENBT which is the original problem.
The start as service is just a side problem which I am not really bothered about. The only reason I mentioned this is to make sure it is not the root cause of my problem. i.e. do I need to run it as service to browse to the PLC?
I have tried EDS files installation, Re-install RSlinx and Harmony files deletion as suggested by people on other threads. But no success
Hi Guys, I have RSLinx Classic V2.59.02 and I am trying to Browse to PLC 1756-L73 through 1756-ENBT/A. I can view the ENBt card but can not...
2,274
I am trying to view some function block diagram logic, but FBD language support is not installed for my machine and I do not believe it was...
1,155
got another problem with ft view machine edition. I cant browse the sample baggage tags, I have refresh all folder but still the tags are not...
1,426
Hello, I have my ethernet/ip driver configured (AB_ETHIP-1) and set to the correct card/address on my computer and, furthermore, can ping the ip...
1,737
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
131
