Cannot browse slc500 or plc-5 controllers with ethernet/ip driver
mhuntwork
Feb 2009
Cincinnati, OH
20
Hello,
I have my ethernet/ip driver configured (AB_ETHIP-1) and set to the correct card/address on my computer and, furthermore, can ping the ip address of a plc-5 controller but cannot browse anything with RSWho in RSLinx(2.55).
I noticed that, on a different network, I could browse the drives and CLX controllers but not most of the SLC controllers.
Is there something simple that I am missing?
Thanks for any help,
Mike
Try the Ethernet Devices driver AB_ETH-1 set up for the PLC-5 you can ping. If it works, something in your network path is blocking the broadcast from the Ethernet/IP driver. Maybe your IT guys don't allow it?
Thanks, I was able to add the controller manually through the eth-1 driver.
I am in the field and only need to see that one controller so I guess I will move on and continue looking into this when a startup isn't hanging over my head!
I appreciate your help.
Mike
I am trying to view some function block diagram logic, but FBD language support is not installed for my machine and I do not believe it was...
1,155
Hi Guys, I have RSLinx Classic V2.59.02 and I am trying to Browse to PLC 1756-L73 through 1756-ENBT/A. I can view the ENBt card but can not...
2,274
Hi Guys I can ping my Ethernet card and browse to the Ethernet card (ENBT) using RSLinx V2.59. But I cannot browse past the ENBT. Cannot view the...
2,123
got another problem with ft view machine edition. I cant browse the sample baggage tags, I have refresh all folder but still the tags are not...
1,426
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
129
