Cannot download to a New AB 1756-L61,Software version 15.01
Coachman
Sep 2006
Maryland
97
I keep getting the message below when I try to download my program
to a 1756-L61 ControlLogix Controller.
"The revision of the offline project and the controller’s firmware are not compatible."
I go into the ControlFlash program and the only choices I get
are the following.
1756-L61S , 1756-L62S ,1756-LSP , 1769-L32E ,it does not continue
because it does not match.
Any Ideas,
Thanks in Advance,
Its a Guard logix controller so you should use Version 14 series with controller its a seperate software. you can not use the normal RSL5k
Hello, What is the Problem: I am trying to download the AOP file for the newest version of the 1734-IB8 module (ser. D 3.031). But when I select...
1,172
I have a micro820 in the field that I downloaded to yesterday. It said it was downloading the ethernet settings (even though they did not change)...
2,760
Dear all, I am trying to setup a entirely new QuickPanel+ (IC755++ series) I have already setup the IP in the unit, and as well my laptop, and I...
4,137
Hi, I have an unknown error while downloading. What could cause this ? Thanks, G
1,540
Hello All, I am currently trying to communication between Citect and Siemens 315 2-dp via Profibus, by using CP5611. My problem is after i...
6,219
