Cannot Open RS View Studio
Coachman
Sep 2006
Maryland
97
Over the weekend I installed Verizon Internet Security Suite,
because I just started Verizon DSL plan. When I started work
Monday I tried to open RS View Studio and I get the following:
FactoryTalk Studio:
Cannot connect to addin object
Cause: 80042089
When I select OK I get
RS Linx Enterprise:
RS Linx Enterprize cannot run on this computer because the
FactoryTalk Local Directory has not been configured. To configure
the FactoryTalk Local Directory, run Start> Programs >Rockwell
Software>FactoryTalk Tools> FactoryTalk Directory Configuration
Wizard.
When I go into FactoryTalk Directory Configuration
Wizard ,and select FactoryTalk Local Directory I get:
Exception From HRESULT: 0x8004204E
What do you think is causing this ,and what is the most simple
way to fix.
Thanks in advance,
Hi all, I am having this strange issue with FT view SE where it won't allow me to open the project. I've attached the error for reference. It...
3,276
Hi, I have a setup (first for me) with a Micrologix 1400, PanelView Plus 7 and a Yaskawa A1000 drive. Everything was working fine on Friday...
2,325
Hi, Im trying to open an old old Siemens WinCC project. It doesnt have to run i just want to look at the project in WinCC explorer. Its...
691
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
350
Hello, I am having an issue trying to open or create new projects which have L8 CPUs inside. I have tried with several versions of Studio5000...
1,475
