Can't connect a pointer (string)
userxyz
May 2002
any
2,768
I made an SCL block.
I have a String parameter, 200 records...
Data_in: ARRAY[1..200] OF STRING;
On the outside of the block I'm trying to connect the right DB with his array of 200 strings (length = 30).
Why can't I connect a pointer ?
Message in S7: Actual data type ARRAY does not fit in the formal type ARRAY Of the formal parameter Data_in
Not sure what goes wrong for you.
I just made a test.
UDT "UDTstrARR" with
..strARR=ARRAY[1..200] OF STRRING[20]
DB "MyStrings" with
..in=UDTstrARR
..out=UDTstrARR
FC2 in SCL
Code:
 FUNCTION FC2 : INT
VAR_INPUT
   strARRin : UDTstrARR ;
END_VAR
VAR_outPUT
   strARRout : UDTstrARR ;
END_VAR
 strARRout.strARR[1] := strARRin.strARR[2]  ;
 FC2 := 100;
END_FUNCTION
in OB1
Code:
       CALL  FC     2
       strARRin :="MyStrings".In
       RET_VAL  :=MW10
       strARRout:="MyStrings".out
      NOP   0
Works OK.
If you do not specify the length of the string, the compiler/editor will assume it is of length 254
As your DB has strings of length 30 in it, you must specify the same string length in the FC parameter, i.e.
Code:
Data_in: ARRAY[1..200] OF STRING[30];
ok
I've rewritten it a little easier, and did not need the input parameter anymore... But, I understand that I had to specify this, I tried it and you're right. Thanks, I learned.
Code:
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
64
343
122
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
153
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
373
