Can't Connect to S7-1500 PLC
TS11894
Aug 2020
United States
Hello! I am able to ping the PLC, detect it through TIA, and flash LEDs. However, when I am unable to download/upload. All Online options are grayed out.
Has anyone encountered this issue?
What is the firmware version of the PLC and the software version, you can these in Online and Diagnostics. Then what is the firmware version you have set in the project, you can see that under Device configuration, double click the PLC and check the Catalog Information.
Hello, this is a brand new task for me. I recently bought a particulate sensor and it communicates with UART protocol or I2C protocol. It came...
2,850
Hello, guys. Need a help very badly. I have a TIA Portal 15.1 installed on a virtual machine and I'm trying to connect to the 1512SP F-1 PN PLC. I...
6,047
I have a Micrologix 1500 that I cannot connect via micrologix/rs232 DF1 cable/driver. I have tried 3 different laptops, tried direct connect with...
5,292
Hi Folks, I have a Micrologix 1500 Series C rev 9 with a 1761-net-AIC connected to a weight transmitter. Communicating via Modbus RTU as Master...
1,077
So I have a Micrologix 1500 LSP that was running a test station, but suddenly stopped (while I was on vacation). It lights up with the power...
2,242
