Can't do a "Write Changes" with Proficy Machine Edition
scalelar
Aug 2006
SE Tn
62
I'm new to Proficy Machine Edition and I'm trying to "Write Changes" to an edited rung without doing a complete download. The help files say the function is on the Controller menu. I can't find a controller menu and the help for the menus don't show a Controller menu. There doesn't seem to be a shortcut either. There is a shortcut listed for PC but not PLC. Any help appreciated.
The only 374 I know of is the IC693CPU374 as it is part of the old style 90-30 family and not the more modern PAC family or PC Control it does not support Run Mode Rung updates. You will need to do a Run Mode Store which downloads only any changed Block.
This is stated in PME's online help but one needs to read all the fine print. :)
You'll just need to be a little more careful about any changes you write to the PLC while it is running. If the change doesn't work out as you expect you'll have to rewrite the original logic instead of simply being able to cancel your edits.
In my opinion that's not a totally bad thing. Just as anti-lock brakes on your car can lead you to drive faster than should on less than optimum road conditions, having the ability to quickly undo your changes may make you less careful about thinking through the ramifications of those changes.
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
46
Hi everyone, I hope you're all doing well. I'm currently working on updating an HMI project for the GP2500, and I've encountered a bit of a...
125
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
146
Hi everyone, I am working on a project that needs to expose the SV (Set Value) of a temperature controller to a SCADA system. SCADA <-...
175
Thank you for any and all responses/help. I have an RSLogix 5000 v20 and a Cognex In-Sight v5.9 spreadsheet (8502P). I can not figure out how to...
146
