Can't get to config screen Panelview Plus 600
mjggjm12
Jul 2013
NH
92
Hi all, I was uploading from a panelview plus 600 to back up the file and there were 6 runtime files in the memory. I need to know which one is being loaded automatically so I can put that file into our program backup files. Unfortunately this must be an older one because the little white box does not come up on power-up. Also, the programmer did not put a "go to config" button anywhere to be able to shut the runtime down. Does any one know of another way to get to the config screen. The software is Factory Talk ME, I believe version 5.0. I am not sure of the firmware version of the panelview.
Thank you in advance for taking the time to help me.
Thanks for the fast reply. I connected the key board but none of the buttons did anything. What button or combination of buttons do I push on the keyboard to shut down the runtime and get to the configuration screen?
Thank you.
Hi I have a panelview 1000 (2711-T10C3) on a machine with an app that runs when the screen is powered up. The panelview is a touch screen, with...
4,651
Hi all, Just checking to see if anybody out here has some screenshots of the Terminal Configuration Screens that I could use for putting a...
1,606
Hi, im trying to go to the config mode on PanelView Plus 600 series A rev. B, but have no luck. Somebody downloaded his own application with no go...
53
103,385
Hello All, I have a panelview plus 1250 I need to make changes to but I am not the original programmer. The previous programmer did not add a...
28,201
When I reset manually(button on the back) and press the white box, it just loads up the program as if the white button wasn't pressed. Any ideas?
9,520
