Can't go online with Melsec Medoc from Windows XP
jinal1481
Jun 2010
Sydney
I just tried to upgrade Windows 1995 to Windows XP in our plant and tried to go online with Mitsubishi PLC. All I did was copied the whole Medoc folder from C drive of the old PC and paste into Windows XP. That folder has Medoc.exe (version 2.02 and all the offline files) Then when I tried to go online with Windows XP, the Medoc application shut down itself. I can browse and look at the offline files fine but I just can't go online. I checked the baud rate and everything and it is same as the old PC. Don't know whether its a licencing issue or it is some settings into Windows XP that I need to change.
Just to provide more info, I don't get any error message when I try to go online. As soon as I hit "F8" or "Alt + o" the Medoc application shuts down itself. I tried running version 2.02 as well as 2.30 but the issue is still there.
I don't know what else information to provide at this stage. but please let me know if you require anymore information.
Thank you in advance.
I had a copy of Melsec Medoc once years back, and it was installed under windows 95 operating system as well. Win95 OS had a different Shell/DOS package, and it would not migrate to w2k at the time. No errors on installation, but would not run as required.
I had to keep an old PC around for software like Medoc.
The best bet would be to contact your software supplier and see if there is an applicable upgrade that is supported under WinXP.
The last suggestion is to operate your PC with software such as VMware, and install Win95 as an OS.
Hope that these options help!
We received a cell that has a MELSEC Mitsubishi FX 2N-80MR PLC installed. We need to access the PLC program for troubleshooting and additional...
1,982
Hi guys! I have problems reading the outputs online from Mitsubishi MELSEC FX1s-10MT PLC in CitectSCADA DEMO version. Is it possible to do...
2,497
Hello All, We have an old Mitsubishi Melsec F2-60MS-U controlling a cup conveyor and a heat seal heads. The conveyor was manufactured by Fords...
2,007
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
53
Hi. I’m trying to upload program from existing PLC S7-1200. Create new project in TIA v15.1 then upload. After upload successfully, go online but...
227
