Can't open RSLogix 5 program with older version
lmccann
Sep 2013
Trumann, Arkansas
This is my first post on this site and I hope someone can help me out. I have a PLC5 program file saved with RSLogix5 ver 4.10 and I only have ver 2.0.47. Is there anyway someone would be so kind to see if they can open this file and save it as something I might be able to open. Thanks.....LaRoy
Welcome to the forum LaRoy.
There are a couple of options.
1) I printed it as a PDF file. See attachement.
2) I exported it from Logix5 to a PC5 library file. You will need to extract all the files from the attached zip file and open the .PC5 file using your version of Logix5, then follow the import prompts.
If that doesn't work get back to the forum and we'll try an old .x5 file format.
Hope to see more of you around here, this is a great forum.
Thanks very much. I really appreciate you doing this. It is a big help.
The PC5 file loaded ok.
The only thing is that the text descriptions and run comments
did not space correctly and the data file names are missing.
Can you do an ASCII export from Tools/Database?
This will create 4 files with the descriptions that I can import.
That should correct the text spacing.
Thanks....LaRoy
Here...
Edit: I think I duplicated the files, just delete the extras.
That worked great!!!
Thanks for the help.
Now I have to refresh my memory on what I did in this program.
It was only 21 years ago that I wrote it!
Glad I took the time to add the comments.
...LaRoy
Is it possible to save or export an RSlogix5 Plc5/80 program in a way that it can be opened using RSLogix5000..?
4,205
I would like to communication with application installation in my printer server via TCP port 5450. i.e ., 71.16.40.200:5450 . How can i write...
442
Uploaded this project from a PLC that we need to make changes to. I am trying to figure out the reason I am unable to open the actual logic. Do I...
2,264
Hello, I am trying to choose from 4 different tank levels (REAL) and choose the greatest number (highest) and set that to open that tanks valve...
1,892
How can I open a file that says "The requested resource is not recognized by the Security Authority. See your Security Administrator."
2,261
