Can't open Studio5k v23 in Windows 11
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello all,
I have Studio5k v23 running on a machine and I am unable to open the software. Every time I try, it acts like it is opening but then closes. I had this issue once before, something about it not being compatible with Windows 11 and I resolved it with something I found on this site however, I am not having any luck getting lightning to strike twice. It's a new laptop is why I lost the ability to open it. I remember someone said to install VM and run Windows 7 but someone else countered with another way. Any help would be awesome. Thank you
This may help
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/1023480
Basically it says to try disabling the startup page in the registry via
HKEY_CURRENT_USER\Software\Rockwell Software\RSLogix 5000\Start Page\Never Show
And if that doesn't work setting compatibility mode for that version to Vista SP2 on the LogixDesigner.exe application in the \Rockwell Software\Studio 5000\Logix Designer\ENU\v23\Bin folder.
124
hello I have 7cp476 cpu why can led always open and No connection
135
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
156
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
341
and then when i open the windowmaker, intouch is shutdown... that's not work that's demo I have 30days demo
179
