Can't reconnect with plc
cdnrookie
Apr 2013
Canada
112
Hey all,
So i was connected to a slc5/05 an all was good. Downloaded the program a few times and then left it sitting for a while. I came back to see it ha lost communication.
I tried to reconnect, deleted previous driver and tried again ( using the same settings), tried different ports and still nothing.
Ethernet is connected to panelview plus 600, rs232 to a USB/232 converter
Anyone have a suggestion? Auto configuration comes with nothing ( searches then says not successful)
Hey all,
Close Logix500. Launch RSLinx - you need to see the PLC in Linx. If it's not showing there, it won't show in Logix500.
Try deleting, readding, reconfiguring the DF1 driver in Linx. If still not showing up, shut down and reboot the PC then start again with Linx.
Or, add an Ethernet switch and link it all together with Ethernet as ozee said LOL.
Windows 7 Pro. 64-bit History : have been working on a Local SE project for several weeks using FactoryTalk View Studio 8.10.00, and RSLogix5000...
21,829
I needed to get 8 values from an Intouch application to a PLC connected to another Intouch application. I decided to setup 4 Suitelink Access...
1,484
Dick this is all based on a separate post from Kid PLC. I have recopied relevant info to ensure I am not repeating partial truths - I hope. I...
5,477
I am not very knowledgable with plc programming but I managed to write a program using the 1756-EWEB as a client socket. I am now stuck in...
2,288
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
67
