WonderWare Intouch Suitelink autoreconnect?
OdinIII
Nov 2012
Georgia
97
I needed to get 8 values from an Intouch application to a PLC connected to another Intouch application. I decided to setup 4 Suitelink Access Names to avoid spending money for another IO server. This works well but I have to restart the main PC's intouch application when we have a power loss on one of the other Intouch machines.
Am I missing a setting somewhere to autoconnect? Is there a reconnect script?
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
152
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
163
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
418
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
190
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
484
