Can't upload station to PG
plcnoob69
Jun 2023
Nigeria
30
When I go PLC - Upload station to PG and select the IP address of the CPU (it finds it), I click OK and get the message "Online: The connection to the target module cannot be established" followed by "The connection module could not be configured".
However, in my project I created a hardware configuration containing only the PS and CPU, and I could go online with it. Not only that, but when I go online it asks me if I want to use the saved version for diagnosis or upload from PLC - I click upload from PLC and indeed I can see the PLCs hardware configuration.
So it means there is a connection and they are talking. So why am I getting those messages?
Thank you for your answers, but I did select the slot 2. I'm so frustrated by this, I can only upload a screenshot but I don't know what more to say other than it's still not working... What else could it be?
NFPm7NM
https://ibb.co/NFPm7NM
Your S7-400 CPU is in slot 3. Select slot 3 in Upload station to PG.
Oh, I'm so silly... it crossed my mind but I thought that it starts from zero (even thought it literally says 3 next to the CPU) because you can actually select slot 0 when you try to upload...
Anyway, thanks
I'm working with a Siemens C7-633P (S7-300 integrated with OP7 HMI) and Simatic Manager V5.3, SP3. My problem relates to uploading the software...
6,927
Hi, Last night, I did a station upload from a 314C CPU. I downloaded these blocks in a S7-315 CPU, but it refuses to download FC10, FB3, FB4...
5,859
S
I`am trying to upload an S7 program from PLC to PG. The plc is also connected to an industrial PC and touch screen. I`am selecting rack 0 slot 2...
4,497
shamus
S
Please help me How to B&R 7CP476.60-1 upload program Backup and download which program should I use. Pvi transfer tool.? And how. Thank you
88
I HAVE A OLD MESSUNG HMI AND I WANT TO UPLOAD A PROGRAM FILE FROM IT TO A USB PENDRIVE WITHOUT USING PC OR SOFTWARE...WHAT SETTINGS I HAVE TO DO...
84
