Caps jr
oldsman
Apr 2003
Hi I,m having trouble. I can up load and down load but can not program online or monitor can someone help me. I have been using and old dos machine but it died now I have to use windows 98/dos. I get message that says can not program online with this controler but I did with other computer. Thanks ED
Are you running Caps Jr. in a DOS box? Windows may not let you have the COM port, or something else may be using it (RSLinx has this bad habit).
Try running it in DOS alone. IOW, reboot, hit F8 when "Starting Windows" appears, and select "Command Prompt Only". Then just switch to your CAPS directory and run it.
beerchug
-Eric
The CxxK family of PLCs has never been able to "program on-line". That feature is hardware dependent and is relegated to the CxxH family.
Thanks I forgot that you can't program online but I still can't monitor the program online for trouble shooting. Thanks Ed
Are you useing LSS or Syswin?
If you work with LSS its not go On Line automatic for monitor.
You need to select this mode in the menu.
Try to use Syswin.
When I started as a controls engineer way back in the ‘80s everyone used all caps when documenting PLS programs and in AutoCAD. This was still...
1,671
Hi, I have a spare compactlogix that I want to use for testing, but I dont have the end caps. Is there a way to bypass this? I just want to use...
3,532
I have colleagues that use ALL CAPS in 100% of their HMI/MMI interface. I prefer "proper" text. We don't read newspapers, books, e-mails...
32
8,965
I have been asked by a client which is a beer producer to check if plastic boxes that are running on a conveyor belt have been filled with beer...
6,798
So i came across this set of logix in a control logix plc, i understand what the logic is doing, but however, i don't understand why they are...
2,182
