Capturing the order of events
MikeVT
May 2008
Holland, MI
83
I am trying to figure out a way to display, via a C-More HMI, from a MicroLogix 1400, what order events 1 thru 8 triggered in - i.e. - what happened 1st, then 2nd, then 3rd, etc.
What I am tasked to do, is monitor 8 transfer switches, and display the order in which they transferred to emergency power. Any suggestions?
Thanks in advance for your help.
Mike
I would use a FIFO, or depending on the reason you're trying to do this, possibly just trending it in 500. Using a FIFO you can monitor each switch address, and move a value 1-8 into the FIFO sized to 8 entries when each event occurs. Whatever order the numbers come in as is the order the events happened.
+1 for LoganB's suggestion.
Just use a either a built-in or roll your own FIFO with integers as your states. Use message displays on the HMI indexed to the output FIFO locations to display the actual events in order.
Thanks gents. I will try this. I was thinking along those lines, but got interrupted, and didn't get back to it today. (The joys of a service tech. The phone rings, and I'm off to solve the next crisis. šŸ˜€)
Hello. I actually still have a customer that has a 486 running a DOS program controlling a press. My task, convert it to an AB PLC and PV+. I am...
24
1,842
is it possible to capture a value while its constantly changing then taking its highest reading? I have a nozzle that sprays for 10 seconds. I...
3,443
Hey all, First time poster looking for a little help. I have a Kinetix 6000 drive that I am capturing faults for in RSLogix but I need some help...
962
Hello PLC Experts, I want to do a logic where in an analog value will be captured per second or in any time possible and move that value into a...
1,615
Processor: Schneider M241 Software: SoMachine 4.3 I am trying to capture the RPM of a shaft using a prox sensor. The shaft has two cams on it...
2,510
