Cause & Effect Tables
Hal9000
Jun 2010
London
140
Hi there,
I'm working on a new waste water process (CompactLogix) project that involves quite a lot of documentation. Within the document list the client has requested a "Cause & Effect Table".
I'm hoping someone could send me a good example of this so I can get my head around what my client is after. I've certainly got the concept of C&E but I've never actually done one before. The examples on the web look quite basic, but I need to look pro with this.
Many thanks in adavance
You must be able to document what happens if a transmitter / sensor fails and what the effect of this failure is.
So a review of the entire control system and find the weak spots in this, and then you have to described what happens if there is a failure.
A failure of a sensor on a wastewater treatment plant can result in poor cleaning, and the same may happen if the sensor is not calibrated with the appropriate time interval.
It's a bit like with risk analysis of safety - what can go wrong and what is done to avoid it goes wrong.
Failures to a sensor can of course be solved by having 2 sensors then you are more sure of the measurement.
I found this which gives information about what it is about
http://www.aidic.it/icheap9/webpapers/41An.pdf
Hi everyone, I need a solution based on the cause and effect diagram, especially a macro sheet or VBA script in Excel, which will help me generate...
80
Not sure how many have seen this by now, but I like it https://www.youtube.com/watch?v=FaR9rVXUkJo Not sure how often it will be used
4,259
Hi Everyone, Does anyone have a good Cause & Effect Excel Spreadsheet for the Automation and Controls business you can share with me? Or a link...
1,246
I am required to supply a cause and effect diagram for my latest project. I have not done this before. I searched this site and found...
2,224
Dear Experts... I heard that there is Cause & Effect diagram to develop the software programming for the PLC/SCADA project....but i didnt seen...
5,718
