CC LINK application
davidelh
Sep 2013
malaysia
Hi Guys,
I need to set up CC Link for Mitsubishi Q series.
However, I have main base unit and a sub base unit. Both located in the same panel.
So im thinking does the CC LINK master module work if i place at the sub base unit. Will it work?
Usually i place it in Main base unit but in this case, the main base unit is fully utilize.
Hi Guys,
This is off of memory. I think it will work, but you need to know how to address the "header" parameters when configuring the CCLINK. It is usually denoted as H#, the number here is to address where the CCLINK Master unit is connected to main PLC. if its connected to the right side directly then the address is H0, if its connected after another module then its H1 and so on. This is only for the right side though. Not sure if its any different on the left side.
Hope this helps
Hello, I am a student of Master Mechatronics and currently in my final semester writing a master thesis. My topic for the thesis is Development of...
4,749
Good afternoon, I have a problem communicating with a system, I will explain it briefly. I have a HIS -ML17- CTBH monitor connected to an...
48
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
116
Hi everybody, I would like to know if anybody here has already programmed with a LR-TB keyence on Io Link on a Rockwell PLC? And perhaps have...
97
Hi everybody, Is anybody here still have programmed a Keyence sensor LR-TB2000CL and used it as io link material in studio 5000. I would like to...
104
