CCW Absolutely Brutal Upload Times...
JZerb
Oct 2016
Here
423
So I have CCW Version 12 and am using a Micro 850. I am having absolutely horrendous upload times from the controller to my laptop. I have a pretty beefy Lenovo that i run VMWare on for all of my Rockwell Programs. When i upload into CCW the software usually locks up, title bar pops up a (not responding) eventually, then if i dont touch anything maybe 8-10 minutes later the upload may complete, or else CCW needs to be end tasked. anyone have any advice?
Sounds like a machine I had to upload the PV1000 [not Plus] project. It was a complicated machine with many screens and tags.
The upload took 35 minutes. Thinking something was wrong mid-way through I aborted and started again, but still the same speed. And, that was with Ethernet comm's.
CCW is stupidly slow but what you are getting is worse than usual :)
CCW under VMWare has dramas with USB drivers. Make sure there is nothing running on the VM that uses them like communication drivers for other packages. Even the CodeMeter app can cause problems with the vm hanging when the vm is shut down.
I am using Ethernet to upload into the VM, so I assume the USB dramas you mentioned aren’t hindering anything for me.
Hey out there, I am trying to build an alarm que in CCW. I have got the FFL and FFU working, however the string that goes with the alarm can't be...
27
294
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
81
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
266
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
187
