CCW HSC
RobertKoto
Jan 2019
Norval
Hello.
Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count. Tried different way of resetting HSC but still sometimes HSC hangs up. have to power down PLC in order to reset it. See attached print out.
Any thoughts on this issue?
  • Encoder_1.pdf
Honestly, those 800 series PLCs and the high speed functions don't really work well.
I tried using the HSC for an encoder and it was always glitchy. I ended up going with lower resolution encoders or creating my own pulse counter logic with limited success. Remember to configure the scan rate on the input terminal or designate it as high-speed. I can't recall exactly the terms they use in CCW for that.
The one this to watch is your controller scan rate with these 800s, too much code can creep their rates to the 1/2 - 1 1/2 second range too easily.
I'm trying to use CCW version 11's built-in HSC instructions as opposed to the UDFBs of older versions. Other than the CCW help files, I can't see...
3,712
I'm having major issues programming the high speed counter function on the Micro 850. I have no more avenues to pursue... I've tried everything I...
8,576
This is my first project using Allen Bradley's new(er) CCW... and I'm stuck. Here's the application: This is a small plastic extrusion machine...
5,074
All- I am new to the Micro830 and the Connected Components Workbench. I am trying to wrap my brain around the High Speed Counters. I am trying to...
2,388
85
