CCW. Keep failing to down load.
Lgillespie.5
Oct 2020
Nevada, USA
I made a program from scratch for my work. I made it for a micro 830 (2080-L30-48AWB) on CCW (connected components workbench). When I got to down load it to the controller through the usb a-B, it builds successful but fails to down load. I keep getting the error:
An error occurred while writing to custom command.
TCPIPObject download failed.
EthernetLinkObject download failed.
Please help I am stumped by this.
I have 1 micrologix 1000 in my facility, the only way I connect to it is with the Micrologix cable,# 1761-CBL-PM02, along with a converter to USB to connect it to my PC.
RSLinx is set to use the AB_DF1-1, DH-485 connection.
Gad
The last time I used that cable it was to slow. I am using the usb a-B cable. I can see it and talk to it but it keeps failing to download the program. Keeps saying failing to write to custom command
Have you tried to download something simple like a couple tags that run a timer?
It sounds like you have connection, but something in the program itself is making it angry.
Try uploading and comparing what you have to whats in the PLC, then download the same program you uploaded
.When I got to down load it to the controller through the usb a-B, it builds successful but fails to down load. I keep getting the error:
Read below
damica1 said:
If your using the USB cable you should not be using the Ethernet driver.
The 830 is not the same as a 1000 and does not use a PM02 cable
78
Hey out there, I am trying to build an alarm que in CCW. I have got the FFL and FFU working, however the string that goes with the alarm can't be...
38
506
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
140
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
293
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
207
